Fans...
10 May 2012
Hey all, i'm wanting some advice with regards to performance using Akasa Apache Black Super Silent 120mm Fans in comparison to the fans 120mm fans i use in my current setup (shown below)
Thanks
surely your zaward fans there are quiet enough? could you hook them to a fan controller? reference cards are not known for their silence also the ocz psu you have isnt quiet either. i had the 650w one and i found that loud tbh.
as for the apache blacks, i found them very quiet but they aint the best for heatsinks. ive got 2 120mm ones on my megahalems and i find them silent
Scythe GT are far from super quiet..I would be looking at the coolermaster sickleflow or akasa apache for sure if you don't like blue leds
