fans
Permabanned
18 Dec 2011
looking to replace all the fans on my watercooling setup so i know require 10 fans, i know corsairsp,thypoons etc are the best fans to get but they are ridiculously expensive.. so i'm looking for a fan with a good static pressure, not to loud at a fair price!
any recommendations?
thanks
Why are you replacing the fans is it due to noise due to running ten fans? Have you thought of putting them on a fan controller would work out cheaper and just reduce the speed thus better silence.
a 360 and 240 is plenty for a 3770 and xfire 7970. Rather than spend twice on poor fans id spend once on good fans get 5 gt15s or sp120s
