fans
21 Mar 2017
UK
any fans that are good that are recommended for the Corsair Carbide 100r case
No competitor links, please read the rules - Thanks, Armageus
Well it depends what your putting in it !
That case has space for 2x 140 mm at the front , 1x 120 mm at the rear and 2x 120 mm at the top
Their are lots of good fans but without a spec its hard to recommend any of them yet
Good, cheap-ish fans are the ML series from Corsair. But really I would think more in terms of how you are going to control them because that may well change which you want to buy.
