Fans
9 May 2012
South Wales
a bit of advice im currently running a h115I platinum 2 x 140ml pro fans and 1 x 120 ml pro fan in a phanteks p400s case. I've just brought the Lian Li XL Rog Dynamic case and was wandering am I best adding an additional 3 x 120 ml pro fand or do the ll120 fans ? also how would you guys set this layout up ?
cheers
Best way to find out is build in the new case and go from there mate.
I'm in the same situation and decided to do that so I can precisely measure the space left and decide whether adding a fan in different areas will actually be of benefit, for example base case fan airflow might be blocked by Pci-e cards.
