fans
22 Oct 2008
Lisburn
I currently have a MetalliGear Neo Qube case, it's basically like a O11 but £30 cheaper.
I currrently have a Coolermaster Master Liquid 360 CPU cooler and 1 Master Fan 360 (It's the block of fans in one unit)
The case allows, like the O11, to have the side triple slot, bottom triple slot and top triple slot option so 9 fans in total (including the 3 on a 360 rad)
I want to change the cooling setup to use these new black 360 coolers from Lian-li (for top triple slot area as exhaust) AND 2 sets of black fans to populate the side and bottom triple slot areas (as intakes)
My basket at Overclockers UK:
Total: £328.67 (includes shipping: £8.70)
Am I right in thinking that these fans AND the fans on the 360 cooler, are the new Lian-Li stuff and not the older version of the cooler and fans?
Is this the best way to get the setup I want, or can I do it cheaper? Thoughts?
I want the case to look like this...roughly speaking with all fan slots populated
Or is there another brand of fans that will look good and have a 360 CPU cooler that will be compatible with all the fans I need, that I can look into?
