I bought a 3850 with a 6 pin PCI-E power input
i then bought a 2x molex -> 6 pin PCI-E power adapter to use it
but the two don't fit.
You have "domes" and "square" shapes on the power adapter, so it can only fit in..
Graphics card wants:
D D S
S D D
But the adapter is
D S S
S D D
Am i right in thinking that the adapter is wrong?
I reallllyy want to get this working...
At the moment, the molex wires are giving yellow cables at the top row, and black on the bottom row (excuse me, not sure what they relate to but i think all molex use the same) - could anyone confirm this for me with their graphics card?
If i try and hack away at the middle Square plastic pin to make it a dome, think it'll work?
Thanks in advance
D D S
S D D
But the adapter is
D S S
S D D
Thanks in advance
Plug it in and see what happens
(thought there was - maybe my memory is failing me
