Pre 24 hour price drop![]()
To be fair,
"Please leave 24hrs before making a PD this is your 3rd strike and MM access will now be removed. "
We can search your posts you know
Setting up automatic feeds would take time I don't think any MM Don has.
This doesn't apply to the MM.
I could have sworn there was a post saying so?
User Infractions are given by Moderators and Admins for minor rule breaks, such as Inappropriate Language, Members Market Rule Breaks and Low-level insults/personal attacks towards other members. This is instead of a suspension for minor offences and allows the moderators to easily inform a user that they have broken a rule. Each infraction type has a points value with different infractions having differing 'points' that remain active for varying lengths of time before they are no longer counted. Most are set at 1 point, except for the Members Market Infraction which is 5. If you get 10 "points" via infractions your account is automatically suspended for a period of two days.
just a copy paste of whatever list you currently use to record bans/infractions then?
The overhead is just too much.
How long can it possibly take to copy paste your bans/infractions + reason log once a day/once a week?
Or is the reason/list written in such a way it would have to be heavily edited/censored to make it fit the posting rules?
Me too. But apparaently when I was suspended and pointed out that it should have been 5 points and no suspension, Burnsy said the new rules did not apply to MM.
EDIt: Yep, it's even in the FAQ that it applies to MM
http://forums.overclockers.co.uk/showthread.php?t=18182899&highlight=suspension+point
http://forums.overclockers.co.uk/faq.php?faq=vb_user_maintain#faq_infractions
As much as I admit I did break the MM rules, I am still purturbed as to why the 3 strikes and your out and instant suspension still applies to MM when the FAQ seems to suggest otherwise and that you need 10 points to be suspended although you get more points for infractions in MM than elsewhere on the forums (which seems logical)?
The use of infractions is not the same as a relaxed modding policy in the MM.
The infractions are used primarily to make sure a member is aware of why they were suspended. This way we prevent people saying they didn't see the warning. The points part isn't used so much now.
I may be bitter because of what's happened in this instance but i think some of the MM rules and policing are completely flawed.
It is recorded on a per user basis. We'd have top copy/paste to a separate list every time we do something.
I didn't see a warning, or an email to say why. Just an email from the thread starter to say sorry for me being suspended.
They are not always completed, due to the time it takes to fill out.
Hope you are not to transparent, I dont want to see your dangle bits![]()
Don't need an transparency cloak for that to happen!![]()
Why am I thinking of you in just a cowboy hat and chaps now?
