FAO EK Rep
18 Oct 2002
Sutton Coldfield, Birmingham
I have a 280mm UK predator and wondered on a couple of things?
1. When do you think the upgrade push/pull fans will listed on OcUK or your website? Only the 120mm versions are currently avaliable.
2. Is there a plan to produce pre-filled radiators with QDCs?
The second would obviously be dependent on case, etc with tube lengths but just wondered?
I'm not sure my 280mm would cope with my 5820k and a 1070 so was toying with adding another radiator to the loop.
Hi,
About the P/P upgrade, I will ask and let you know when we intend to release this.
About the pre-filled radiator, we currently don't have plans to do it.
I'm pretty sure that adding in too many qdc links to a system (let's say CPU, GPU and then a second radiator) will impact on the pump too much. The qdc act as bottlenecks in the loop. Obviously you could upgrade the pump, but you still could find too much stress on the loop if you were using multi card cooling.
We will have a push/pull upgrade kit soon. It should be release somewhere in December. I just don't have the exact ETA for now.
