FAO Elysium Case Owners
29 May 2012
Dorset
Wonder if one of you can do me a favour
Looking at build options and am wondering, with a OCZ Modular Evo Stream PSU at the bottom of the case is there enough room to slot a dual 120 rad in the bottom as well without hacking the case apart?
the evo is 150mm wide
Thanks
Well, I have done some rough measurements on mine to see how it would look.
It depends, I think. You say the PSU is 150mm long (I presume?), but what about the cables?
From what I measured, the back of the case to where the perforated holes stop is roughly 440mm.
Given the average length of a dual rad at 275mm, you are looking at 425mm, so it would fit if you can arrange the PSU cables out of the way.
Of course, all this could be irrelavant if someone who has actually done it or has more knowledge on such matters replies :)
I just happened to have the case and a ruler, so I am afraid this is all I know.
Or you could just put the PSU in the top, or the rad in the front :)
Im planning a twin rad system and with 2 dvds 3 hard drives and a twin bay pump and res I dont think I could loose 2 bays due to space
