FAO Excel Gurus
29 Jun 2004
I have 36 worksheets in file.xlsx. Except from the different data each worksheet contains, they're all in exactly the same format.
Say I wanted to do (A1+A2)/A3 for all the worksheets, how do I do this?
Say I wanted to highlight cell A4 for all the worksheets, how do I do this?
Thank you for your help! :)
You can select multiple sheets using ctrl across the bottom. Then if you edit a cell, it will replace the cell in all those sheets.
