FAO Gibbo - Intel E4300 ETA?
12 May 2005
Gibbo, I dont suppose you know if OCUK will be getting these amazing little chips in?
I was thinking of grabbing one in place of an E6300, and then just waiting to the end of the year to grab a quad core.
HI there
Yes we go orders in place, expect them in 1-2 weeks. :)
Gibbo said:
HI there
I must say, OCUK CONTINUE to....
Impress Me. I think I will leave the system I was going to buy on hold for a few weeks then, was going to buy it next week, but will probablly wait till start of feb time, that way at the least I can have the money to get hte 8800 GTS, and get one of these beauties :)
HI there
They will be on the website available for pre-order in 15 minutes.
Pricing is so so, am hoping with time it might improve by about £5-£10. :)
This makes buying any of the Allendale chips a bit pointless at the minute doesn't it as bassically they're being upgraded to Conroe and another chip taking their place. Hmm, will these newer E6320 be better again at overclocking?
4300 just went up for £100, not much of a saving over the 6300 but hopefully as Gibbo said they will go down a bit.
Jabbs said:
Hmmm a lot more than i thought they would be was expecting £95 maybe.
If they go down to about 99 or something I will grab one, otherwise I don't see the point in the 4300 and will probablly get the 6300 instead.
BUT they are only pre-order, hopefully they will go down :)
The advantages this has over the 6300 is a x9 multi instead of x7 on 6300, same cache, so basically they should over clock far far better than a 6300.
Pretty much the same clock speeds at stock, just means like for me to hit 2.8 i need 400x7 to reach it on me 6300, on one of those you wouldn't need such fast ram , for example the same on the 4300 400x9 would hit 3600 effectively, to hit 2.8 you would only need 310x9 ish.
/be kind
I guess that the lower FSB of the CPU means nothing then? because you are overclocking?
So tempted to upgrade my rig to a little Micro ATX Core 2 Duo system.
Managed to spec this little lot:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
BFG GeForce 7600 GT OC 256MB GDDR3
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache
Lian-Li PC-V300 Aluminum Micro ATX Mini Tower Case - Black
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard Seasonic S12 430W Silent ATX2.0 Power Supply
for around £550.
Might as well wait a bit longer for the E4300. Even if I don't go for one, I'll be able to pick up the E6320 with its 4MB Cache.
for around £550.
Are they 6320 released at the same time as these then?
trojan said:
Trojan - According to ocUK they run perfectly with 64 bit... http://www.overclockers.co.uk/showproduct.php?prodid=CP-142-IN
Not sure. I was reading in one of the reviews that the E6320 with 4MB cache will be replacing the 2MB cache E6300 at exactly the same price.
Another significant update coming in Q2 is that the low end 6000 series Core 2 Duo processors will receive 4MB L2 caches like their more expensive brethren. Currently the E6300 and E6400 both have 2MB L2s, but both chips will be replaced by 4MB versions - the E6320 and E6420 respectively. Clock speeds and other details won’t change, but performance will obviously increase. The best part of it all is that pricing won’t change either, so if you’re contemplating buying an E6300 or E6400 you’d be better off waiting a quarter so you can get the extra cache for free.
From Anandtech
When is Q2? Was looking at buying a E6300 in the next couple of week for my new system, but if the E6320 are going to be out fairly soon then i may as well wait.
