Bit of a heads up,
There is a known issue with this combination. I’ve had it running since release but this afternoon, after a reboot, every single internet application crashed on start-up except for IEx64, it was cringe worthy using to find the problem
. Only an uninstall of NOD32 allows you to return to normal, I’ve yet to reinstall but others have and resumed usual service, reoccurrence of the issue isn’t known.
Might be worth using something else or informing those less literate on the procedure to take if this happens to them, the main reason I’m adding this here is if anyone does a search with the problem this should turn up. It took me quite a while to find how to fix it and OcUK was my first port of call, hopefully this will help someone at some time.
URL’s of relevance:
http://www.vistahelp.ca/phpBB2/viewtopic.php?t=263&view=next&sid=42f0ded3e00e3a23fc93b731c10591a9
http://www.wilderssecurity.com/showthread.php?t=166844
http://www.hardforum.com/showthread.php?t=1163489
http://forums.anandtech.com/messageview.aspx?catid=34&threadid=2013960&enterthread=y
OcUK forum search terms (Sorry, not sure if this breaks the rules, it’s not listed but I can see it being added at some point if lots of people started using OcUK as a knowledgebase like this)
Internet applications crash on startup, Firefox crash on startup, Nod32, IE64.
URL’s of relevance:
