Just a question regarding your headunit, and phone.
IIRC you said you used an imate JAM with your headunit, does yours auto connect? I've recently got an imate K-JAM (WM5) and I cannot get it to auto connect. I think the promlem may be down to not being able to discover the phone from the headunit, I have to add pair it on the phone.
If I manually connect the HU to the phone, it works fine, but won't auto connect.
Have you had or heard of a similar issue?
Cheers
Cheers
