FAO [TW]Fox
27 Aug 2003
West Midlands
Hey Fox,
I remember seeing pics of where you have your tweeters mounted in your car.. did these mounts come with the speakers themselves? If not, where did you manage to find them?
Cheers
ScoobyDoo69
ScoobyDoo69 said:
Hey Fox,
Cheers
ScoobyDoo69
Mine should arrive this week (same speakers as Fox's) so i can take some pics if you need them.
ok great guys, thanks. I'm not too sure if the speakers (if and when I order them) will come with any similar sort of mounts... but I'm sure I could probably find something similar!
ScoobyDoo69
I have infinity tweeters in mine. Didn't use any mounts that came in the package though.
I fitted mine behind the little grille by the door handle (you have MY98+ onwards interior like mine) Hardest thing was finding a place for the X overs.
Yeah that's where I have my current ones... but as the tweeters were an extra to start with... the actual mounts behind the little grille are not there.
I did put a wanted bit up on scoobynet... but never got anywhere with getting them :(
I tried to think of the most "Cowboy" way of mounting them so used those double sided strips you can get to mount numberplates.
Been on for about a year and haven't fallen off yet :)
