- 26 Dec 2002
- Derbyshire
I had this happen to me this morning - very annoyingZefan said:My FahMon sometimes doesn't actually come up, it appears on the taskbar but wont maximiseI have to delete it from my folding folder then re-extract it and configure it again. Sorry if I'm hijacking but the original point has been sort of cleared up anyway
 however I've found a much simpler cure
 all you have to do is delete the prefs.dat file from the config folder and that'll reset the preferences to their defaults - this'll save you having to set up all the machines again and you won't lose the benchmark figures
I think the problem is probably caused by the "enable system tray icon" setting though it's never done it before this morning
