FAQ question for SIGNITURE!!!!
Status
Not open for further replies.
16 Jul 2006
NZ
Hi Everone
Just wanted to know if this size is ok for signiture as last one I ended up with one of those yellow mesages but I have now made it smaller but is it to still to big here it is
Thanks in advance :)
Nope, its 80Kb. You need to get it under 20Kb.
"A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels."
Those are the rules you need to stick to. :)
Edit; That wasn't quite called for Zefan.
Status
