far cry 3 help
6 Mar 2008
Stoke area
Hey,
Decided to install Far Cry 3 for another play through. Updated to 1.0.5, played through for about 6 hours last night and turned it off when I went to bed, loaded it up and I have to start from scratch.
Had a google and changed orbit_api.ini to "GameId = 48", played the intro and saved it. Quit to main menu, and have the option to load/resume. Quit to desktop and reload and again, only option is to start from new.
On top of this and the graphics issue I had where it would quit after the intro mission just after you escape I've played the intro about 8 times now and it's really starting to annoy me.
Any advice on how to get this sorted?
My save games are in C:\Users\All Users\Orbit\48 with the right times on etc.
Like buffalo says it could be trying to load from a cloud save that doesn't exist.
Turning off t'internet should force a local save at least.
I had a similar issue with another game once, it was solved by deleting/overwriting the Cloud Save on Steam. So GBRusty is probably right.
After hours of trying to get the DVD version to work, I decided to buy the digital copy on Steam for £5. Works a treat!
