Far cry bench bench
25 Jul 2007
Essex
Does any one get the following results with similar spec as sig? Just want to check I am not too low or something.
Settings: Demo(Playback (Demo Ranch)), 1600x1200 (85Hz), D3D9, Fixed Time Step(Yes), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(2x), VSync(No), Overall Quality(Custom), Vegetation(High), Shading(Very High), Terrain(High), Geometry(High), Post FX(Medium), Texture(Ultra High), Shadow(High), Ambient(High), Hdr(Yes), Bloom(No), Fire(Very High), Physics(High), RealTrees(High) Loop 1 * Total Frames: 1110, Total Time: 31.64s * Average Framerate: 35.08 * Max. Framerate: 41.42 (Frame:91, 2.39s) * Min. Framerate: 28.41 (Frame:1067, 30.26s) SVG not loaded! View larger version Loop 2 * Total Frames: 1110, Total Time: 31.93s * Average Framerate: 34.76 * Max. Framerate: 41.54 (Frame:102, 2.69s) * Min. Framerate: 28.10 (Frame:1070, 30.62s) SVG not loaded! View larger version Loop 3 * Total Frames: 1110, Total Time: 31.58s * Average Framerate: 35.15 * Max. Framerate: 41.99 (Frame:97, 2.55s) * Min. Framerate: 29.35 (Frame:1070, 30.29s) SVG not loaded! View larger version Average Results * Average Framerate: 35.00 * Max. Framerate: 41.41 * Min. Framerate: 28.64
looks ok
Your average frame rate of 35 looks fine for your spec rig (by the way i found it easy to read).
