Far Cry Cheats
9 Aug 2004
Milton Keynes
My partners, sisters, son wants to play on far cry but gets killed near on as soon as he starts so basically are there any cheats for it, I did try looking but only can see change level commands
And b4 any1 says cheating is bad, hes young
heya,
theres plenty out there.....google them to find out
i downloaded the savegame files from one website,its german but it works on the uk one aswell.damned if i can remember the website though :(
happy hunting,
steve.
On the Shortcut to the EXE, add the command -DEVMODE to it.
So, the link will point to something like
D:\Games\FarCry\bin32\FarCry.exe -devmode
And also have a look for the file called devmode.lua and then add this bit of code to the end of it:-
function ToggleGod()
if (not god) then
god=1;
else
god=1-god;
end
if (god==1) then
System:LogToConsole("God-Mode ON");
else
System:LogToConsole("God-Mode OFF");
end
end
Input:BindCommandToKey("#ToggleGod()","backspace",1);
Now, whenever you press BACKSPACE in the game, you will ENABLE / DISABLE GOD MODE
Also, if you press "O" or "P" you will get max ammo and max weapons.
Now, if oyu are given a weapon, it has no ammo in it, so select them both to get all the ammo for that weapon.
Erm...
As mussler said...
Google - "FarCry Cheats"
And reap the benefits.
Also, there is no harm in cheating... Sometimes it helps to keep[ a game alive if you are stuck in a certain place... I mean, I would rather cheat then stop playing the game just because I am stuck at a silly point, btu also cheating too much will also ruin the game too.
