Far Cry HDR+AA
ATI
ATI
9 Aug 2005
hello all
ive got a x1900xtx and i want to run farcry AA+HDR,
can some one gimme a ahand or show me a solution to see this game in its glory, any help is appreciated
cheers
ATI said:
hello all
cheers
You will need the bugy as hell 1.40 leaked beta patch.
hi
i just downloaded it, i followed the instructions,
in the CCC its on the let application decied for aa
- changed the AA to 6x in farcry video option
the game starts with all the aa rendered as soon as i use this command like it says on the read me (\r_fsaa 2) than it turns of the AA completely.
than the i try the hdr command, the hdr kicks in but the aa remains the same which is 0.
i just cant get it right, have you managed to do it or anyone?
ATI said:
hi
I think you have to have AA off in game & force AA in CCC to have AA/HDR just like Oblivion.
You cant control HDR from CCC but you can control Force AA from CCC thats why you have to have AA off in game and force it with CCC.
so your saying
- turn the aa on in the ccc
- make sure the aa i the game is turned off
- than after the level is loaded (add these commands \r_fsaa2 & \_hdrrendering 7)
something like that you mean, have you seen it working on your card or tried it?
thanks
ATI said:
so your saying
thanks
Dont turn on any AA options in game or it will not work. \r_fsaa2 is a no no!
Set the AA level you want in CCC AAX2 slider & you will have AA2 in game with out selecting \r_fsaa2.
so basicaly
no AA in the game
set it in the CCC
and than load game
and load HDR and that should be it
is that it or what u mean
hi
this is what i done exactly
in the ccc i set the AA @6x
in the game the AA is set to none
as soonas the level finished loading i entered the \r_hdrrendering 7 command and than all the AA is lost, the hdr works but no AA.
do i need the chuck patch you reckon?
the game is updated from 1.3, to the latest 1.40 and still not working, i,m beginingto think that this is a no good patch, as i,m sure in the firingsquad review they enabled the AA & HDR.
http://www.firingsquad.com/hardware/hdr_aa_ati_radeon_x1k/
ATI said:
hi
The patch is beta the chuck patch may help.
Man ive just installed this again after playing it donks ago on my old 9800pro, absolutely belts along on my x1800 maxed to the hilt, and it still looks amazing today, might go trough it and complete it again. :cool:
Brought back some great memories, when he pops out of the cave and see's the island below, and the cracking water, and the parrots flying about etc...., and the awesome shadow effects of the leaves over yer gun and that. :cool:
