farCry HDR
7 Mar 2005
Wolverhampton
Could someone help me getting this to work?
I type the command in but nothing happens? I have patch 1.33. I dont know what else to do !!
killer_uk said:
Have you typed the command correctly? \r_hdrrendering 7
Have you turned on "let the application decide" in the CCC for AA?
yes, thats what i typed. I have ati tray tools set to "application decide" for everything.
AA says "none" and AF in advanced options says 1 (cant get it any lower)
The command still doesnt work?
I'm having the same problem. Works fine with the beta 1.4 patch but its FAR to buggy to use. Don't understand why it doesn't work with 1.33 installed.
I had it working last month. Now i cant do it. And ontop of that its artifacting to high hell again lol.
1.33 only supports HDR for NVIDIA cards.
1.4 final should be out very soon, and unless it was taken out since the leaked patch will provide HDR for ATI.
FYI, if you run HDR in multiplayer, you will get kicked from most punkbuster enabled servers due to a bug where the AA and HDR interact to make the walls see through.
I had that see through bug on the training level in singleplayer. It was so bad that i didn't know where i was going :(
Weird... Allegedly you shouldnt have been able to without 1.4...
The fact that you are getting artifacts isnt right though.
How did you get it back to 1.33?
Always best to clean install then only patch 1.3, 1.31 and 1.33
Or there is a community built 1.0 to 1.33 all in one patch, DL links are available in the tech help section on the UBI forum. (Cant access it from work or I'd post the links)
Have you clean out your drivers with Driver Cleaner Pro recently?
What happens when you enter the command?
Does it echo back the setting you made?
if you type \r_hdr then hit tab, it should display all of the HDR cvars does it now reflect the setting you just made?
One thing which caught me out when I tried using HDR in Far Cry, is that you have to set the lighting quality to at least "Very High" (I think) or it won't work.
Or maybe I'm getting confused with SM3.0. Ho Hum.
What is this HDR? and do you need a special HD monitor to display it? I have a Samsung SyncMaster 930BF 19" tft and a X1900XT would this do?
It stands for High Dynamic Range and is to do with the lighting in a game. It's your graphics card and not the monitor that needs to support it. Yours will work fine.
This might explain a bit better.
