FarCry help needed
10 Mar 2006
Hi
I've installed the latest patch and the 64bit textures for Farcry. When I'm playing the system speaker keeps beeping constantly. I do have both my cpu and x1900xt slightly overclocked, but this also happens when running stock speeds. I've tried running the card really underclocked, with the graphics card fan blowing at 100%, but it still happens.
This is the only game this happens with.
Could this be a problem with the 64bit texture pack? I've also tried the 1.4 patch and also turning down all the graphics options, but the speaker is still going crazy.
As soon as I press escape the beeping stops. Even just moving the mouse around can stop it sometimes.
Anyone else had this? Or know of a solution?
Thanks!!
Do you have other monitoring software installed like Speedfan or Motherboard Monitor that perhaps gives an alarm?
Mine beeped once ot twice during the earlier levels and then stopped. I found out it was Asus Probe complaining about one of my case fans spinning too slowly. Not had the problem with any other game. Weird. Very weird indeed.
Could it maybe be a PSU problem?
I have a Tagan TG580-U15 580W PSU
Here's a graph of the 3.3V I took whilst playing Far Cry:
The other voltages looked pretty stable.
Could this be the source of the constant FarCry system speaker beeping?
Paul -C- said:
I went for a shower and left the computer idle for 15 mins.
Here's what I've came back to:
I take it this isn't good?
Its probably wrong, theres no way your pc would actually be on and working if it dips that low, theres only a 10% tolerence on the rails,
I would take those with a pinch of salt tbh,
Question:
Do you need Windows XP64 to run FarCry 64bit or will my 32bit Standard windows xp pro, run it?
I've ran Asus Probe alongside Speedfan and it looks like Speedfan is way off, as suggested above. The 3.3V value is pretty stable at 3.33V
Anyone got anything else I could try?
Just bumping this with my solution...
My Tagan 580W PSU was set to Split mode.
When I set it to Combined I could play Far Cry without any beeping :D
