Starzy said:Thanks for all the help guys, can't believe how good it still looks![]()
Starzy said:Just noticed that the patches are on the DVD. Bit stupid really.![]()
Admiral Huddy said:You've bought an 8800 and are playing a game over 3 years old?? Bit dated now.. Why not try S.T.A.L.K.E.R.?
Admiral Huddy said:It's good but buying an 8800 to run it on is a bit of waste![]()
Anim said:dont patch up to 1.4, it will make the single player aspect worse, 1.3 should do you fine.
Cyber-Mav said:run farcry with 64bit content batch and you will be chuffed. can easilly tell the difference between baddies and rocks![]()
FrostedNipple said:in what way does it make it worse, i don't really understand what you mean when you say aspect
CuZ said:There is a bug in the 1.4 patch that allows mercs to see and shoot through some of the buildings. Its most noticable on the pier level. The Mercs in the garage at the main camp can see and shoot you from inside.
The intention was to allow tents to be shot through in the multiplayer game, unfortunately non of the patch team, Crytek or UBI tested that sufficiently in the single player mode...
If you are just playing single player you should use patches 1.3, 1.31 and 1.33 (1.33 adds SM3.0 for ATI cards)
