Hi all, I'm looking for a recommendation for faster DDR4 ram.
I've built a PC as a dedicated music production workstation. I needed it powerful, quiet and reliable.
I opted for a Ryzen 7 5700G as my DAW isn't optimised for GPUs and this way it's a clean and simple build with no graphics card.
Motherboard is an MSI B550-A PRO
Currently running Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200Mhz which is single rank according to Thaiphoon burner.
In my DAW, the heavy rendering jobs I want to speed up hardly get any of the CPU cores really working, typically all logical cores are approx 30% load with none over 60%, so I suspect that it's possibly a memory bottleneck issue as this improved when I enabled XMP and went from 2133mhz to the current 3200mhz
I've watched a load of videos benchmarking and explaining memory on Ryzens and 5700G specifically, but almost always it's for games performance and on systems with decent graphics cards, so once the memory speed gets past a certain point, it's not restricting graphics performance any more and the benchmarks don't tell me much about workstation performance.
MSI quote the following for the B550-A Pro
1DPC 1R Max speed 4800 MHz
1DPC 2R max speed 3866 MHZ
2DPC 1R max speed 4000 MHZ
2DPC 2R max speed 3600 MHZ
Does that mean I could reliably use 4800mhz single rank ddr4? Will the Fabric clock even run at 2400mhz on these boards?
I originally opted for 32gb memory, but even on massive projects I'm using just under 50% of this, so I don't mind whether I fit 16gb or 32gb.
What would you choose? Is it worth considering dual rank dimms or is any performance benefit negated by having to run a slower memory clock speed?
thanks,
James
thanks,
James
