Fast lenses..
1 Sep 2005
Scottish Highlands
Like really fast lenses. Any idea how much any of these go for, and where one would look to pick one up?
Repro-Nikkor 85 mm f1.0
Mt. Prospect 90mm f1.0
Rodenstock XR-Heliogon 68mm f1.0
Nikon 35mm f0.9
Kowa 62mm f0.75
Rodenstock TV-Heliogon 42mm f0.75
Or any similar? Not looking to buy at the moment, but im just curious.
Surely they're nigh-on unusable wide open? Just reading about the DOF problems Kubrick had in Barry Lyndon with that Zeiss f/0.7 is enough to put me off.
Edit for a bit more substance:
John Alcott said:
The objective was to shoot these scenes exclusively by candlelight - that is, without a boost from any artificial light whatsoever. As I mentioned earlier, Stanley Kubrick and I had been discussing this possibility for years, but had not been able to find sufficiently fast lenses to do it. Stanley finally discovered three 50mm f/0.7 Zeiss still-camera lenses which were left over from a batch made for use by NASA in their Apollo moon-landing program. [...] But when you looked through this lens it appeared to have a fantastic range of focus, quite unbelievable. However, when you did a photographic test you discovered that it had no depth of field at all - which one expected anyway. So we literally had to scale this lens by doing hand tests from about 200 feet down to about 4 feet, marking every distance that would lead up to the 10-foot range. We had to literally get it down to inches on the actual scaling.
The point of focus was so critical and there was hardly any depth of field with that f/0.7 lens. My focus operator, Doug Milsome, used a closed-circuit video camera as the only way to keep track of the distances with any degree of accuracy. The video camera was placed at a 90-degree angle to the film camera position and was monitored by means of a TV screen mounted above the camera lens scale. A grid was placed over the TV screen and by taping the various artists' positions, the distances could be transferred to the TV grid to allow the artists a certain flexibility of movement, while keeping them in focus.
They're a nightmare requiring multiple people to keep things in focus even when you're directing actors and have shots planned out perfectly, I can't imagine what they'd be like trying to do it single-handed with a less cooperative subject—well, I can, and I imagine it would be possible.
