Fast PC for basic use!
14 Nov 2014
Hi everyone!
I'd like to think I'm pretty good at choosing out parts when it comes to higher end PC's but I really don't know what to pick when it comes to lower end systems.
My mum uses her PC like most mums, browses the web, looks at pictures and videos etc. She does however sell a lot on ebay and therefore usually has loads of tabs open, images open and so on. She currently has an OK PC. Here are the main parts
Specs
  • CPU - AMD Athlon II X2 220
  • RAM - 4GB DDR3
  • Integrated Graphics (Nvidia)
I just added an SSD to her system and obvioulsy it's much faster but it still struggles a bit when opening lots of tabs and such. I was just wondering what else would be worth upgrading. Would it be worth upgrading the CPU, adding more RAM and/or adding a dedicated GPU. If anyone can help and give me some adive I would be super happy!
Many thanks,
Tom
More ram for lots of open tabs yeah.
The slowdown you are experiencing is when you run out of system ram and the system has to dip into virtual memory.
CPU - AMD Athlon II X2 220, Sockets Socket AM2+
Socket AM3
you need to recheck the board model etc, very limited upgrade options for am2+/am3 cpu wise
Thanks for the help so far guys.
I was thinking something like this then
My basket at Overclockers UK:
Total: £171.02
(includes shipping: £11.10)
I can get some of the components cheaper at other places and I'll be waiting for the black Friday deals before I buy anything but this will probably be pretty much what I go for in the end. Would it be worth getting a GPU then? And if so which one?
The G3258 is a great little CPU, and I would defo recommend it.
You will be able to overclock it to 4.0-4.2 with that board and with the stock cooler.
I doubt your Mum will need to add a gpu.
