Thought I'd do a little project and try to build a mid-range gaming system using some old and new parts and see how cheap I could get a half way decent system together. Had a spare E6300 I had bought for my son's gaming rig but upgraded his to an E6600, an old colors IT 600W power supply, a bunch of old cheap PC3200 CAS3 DDR, an old Bliss 512mb 6800GS (was ok in this system but have just upgraded to the Gecube x1950XT AGP with TEC (peltier for us old schoolers) an old Alien Plastic knock off case (great case with excellent cooling, even has vents on top to blow all the hot air out of and an old Dual Layer DVD writer.
Bought new Asrock Conroe865PE (only stable up to 312FSB), Seagate 500GB HD, thermaltake Power Express GPU PSU (the X1950's are amperage hungry and didn't trust the Colors PSU). So with new parts about £250 and old parts laying around but costing about £450 when purchased, I have a decent gaming rig that scored 5994 on 3dMark06 (see below) and runs everything I thow at it on my 21" 1680x1050 monitor (bought new for £150) very well.
I highly recommend the Gecube also, without it this would not have been possible. Clocks well also for the core below I had it at 715/810. Because of the TEC it doesn't go over 70 degrees too! The C2D does 3.2GHz at stock but because of the 865PE chipset I can raise the FSB high enough to get a good CPU score which would have pushed 3dMark score up another 500+ points or over 6500 but pretty happy with this! Would almost like to get a multi unlocked CPU like the X6800 or QX6700 but that would defeat the purpose of this project!
Can anyone beat that? I can't search the orb site well enough to compare against AGP but it looks pretty good against single card PCIe systems.
http://service.futuremark.com/compare?3dm06=1731001
Daz
Daz
