Fastest AVI -> DVD
A2Z
A2Z
Permabanned
9 May 2005
Earth
Whats the fastest programme that can convert a .avi to a dvd file and burn it?
Needs to be able to make a main menu.
Tried Nero Vision but for some reason wont play on any dvd!
Thanks
Any 64-bit applications of software?
Encoding on my x2 AMD takes quite some time, and was wondering if having an x64 version would speed things up?
DVD Flick is what I use, it also creates simple yet effective menus. It uses IMGBurn for the burn process (integrated into DVD FLick, launches and closes by itself) so compatibility with DVD players is 100% solid.
a E2140 @ 2.2 Ghz will convert a movie at roughly 2-3x speed. i.e. 20-30mins per hour of source material. Which was a nice upgrade from myXP1900 which was about 2-3x LONGER than the source ..
