FAT 32 and partitioning?
14 Oct 2009
UK
Ive got aload of movies i want to put onto my ps3 and i have a large external hard drive and i have been told that i need my hdd to be in fat 32 as it is currently in NTFS but i have a lot of things on my hdd i need so is it possible to make a partition on my external and make the partition fat 32 so i can use it for copying things to ps3 or do i have to do the whole thing?
If it is possible what program is recommended.
Thanks
you can partitiion part of it, I don't know the softweare for it, without using linux :P
It wont work on windows, I dont think. Formatted my 16GB usb stick using some software i found "google hint hint :)" 50/50 fat32 and ntfs. and windows will only allocate a drive letter to 1 of the partition at a time so it was a waste of time :(
and again the answers i got was it will only work on linux. in the end I got 2 usb sticks. my situation was I needed music for me car and my car radio uses Fat32 and I wanted ntfs for file transfers larger than 4GB but fat32 wouldnt allow that. so I came up with the same plan but it wasnt to be :(
Boot from gparted live cd. Make two primary partitions (not logical), format the first one (left hand side of picture) to fat32, right hand side to ntfs. Done.
^ I also booted a live cd and did that, it loads into windows and see's one partition. then when I go to drive management and select the drive letter for the other partition it deletes the drive letter on the 1st partition. so it will only allow 1 drive letter allocation at a time. :(
