Tommy B said:
By the way, I just bought an up-scaling DVD player. I've wired it to my HD TV using an HDMI cable, but I can't decide on whether to use 720p or 1080i?
Which is better?
You'll find posts and reviews all over the web that claim one or the other is best, but after doing some testing myself, the answer comes down to how your screen and player together handle each format.
I've seen a review of my player where the reviewer prefered 720p, but when paired with my screen, 1080i gives better resolution
and smoother movement, so my choice was really easy!
This is one of those times that unless you can find someone with the same kit as you, you're going to be left with having to do some A - B comparisions.
I'd suggest you try watching for differences between the two in how they handle movement first, as I've always found that more annoying and easier to spot. Look for camera pans with quick movement and some with slow. Watch the whole pan with 720p and then repeat with 1080i - some film credits can be of use here too.
Resolution is a bit more tricky, but find scenes with a lot of detail and again, just swap between the two.
