Hi all wondering if I can some advice. Tonight Kris had a gaming session on Battlefield 2042. He Played for an hour and a half on ultra settings. Resolution: 3840 x 2160 @ 59.997Hz
Below are the screen shots of what HW Monitor reported
Pretty sure I’m right in saying his max temps
CPU was peak 69.5C
GPU was peak 60.5C but HOT SPOT was 72c
Max CPU Clock was 4.84Ghz across all 8 cores.
So the system doesn’t have any OC applied, the only change I’ve made is the DOCP option and the mem set it’s self to 3600mhz.
What should o could be applied/tweaked. Can his RAM go faster speed or tighter timings or both. Any tips
