Guys,
Im after some advice regarding fault finding one of my machines. I was typing away on my machine, and click, the machine switch's off. I try the power switch, no response. No fans, nothing. I check the light on the motherboard. Its flickering on and off wildly, no set pattern.
I turn the PSU off and on at its switch, same flickering. I try another power lead. Same issue. I take the PSU out, and test it in a known working machine. The other machine boots fine. I dont have another PSU of sufficient wattage to test the broken machine, and I dont have a spare AM2 motherboard or CPU.
At this point in time, Im assuming that the problem is the motherboard. From past experience, and what Ive read, if it were simply the CPU, the machine would at least power on (perhaps give a beep code complaining of a duff/no CPU). However, before I go and purchase another, I wanted a different perspective.
The hardware is as follows:
MB: Asus M2N-SLi Deluxe
CPU: AMD Athlon 64 X2 500+
PSU: Antec EarthWatts 500W
Its not overclocked, and has been rock solid since I bought the bits back in January. While I'd like an excuse for an upgrade (CPU, GPU, MB), I really can't warrant it at the moment as all the games I play run really well.
So - advice if you will? Thanks in advance!
