- 11 Sep 2011
- Reykjavik, Iceland
PC has recently started to have trouble turning on.
I switch it on, and the fans start going (loudly as they do for the first second or 2). However, sometimes it just stays in this stage with the fans running but nothing else happening.
Normally, after a couple of seconds it beeps and then finds the drive and OS (Win7) and boots up.
If I then hold the power button until it turns off, it just does the same again and again. The ONLY way to get it on, and this works 100% of the time is to turn if off at the plug, while it is stuck trying to boot up. Then turn it back on at the plug and it works.
Is this likely to be an OS fault, or a drive fault, or something else?
I've tried al lthe connections and that doesn't seem to be the issue. Nothing is loose. Once it's on, it works perfectly fine. It does it about 1/3 times now.
