- 22 Oct 2003
- UK, Brighton
Hi Lads, i have a system that is playing up, (my brother in laws)
when the system is booted up it gets to the windows Xp Loading bar then when the desktop should pop up on the screen it just stays blank i have checked connections and at bios post you have text etc,
i have changed out GTX for a pci vga card and it does exactly the same bit wierd eh?
i have tried last known good config, safe mode will not complete even though i can see the hard drive is being accessed still, i can get a An Xp live cd will display the desktop though as this runs off the CD, i reckon it could be a software problem?
but before it failed posting i unistalled GTX driver, as there was corruption on screen not the lines across the screen, but like open dialogue boxs that have note been refreshed and are corrupt Etc (hope that makes sense),
any suggestions or thoughts lads would be great.
Spec:
Xp Home Sp3
Gigabyte - 965P-DS3
Core 2 Duo 2.4ghz
2 gig Geil 800mhz
Xfi sound blaster Plat
BFG 8800GTX oc
Corsair 620w Hx
SAMSUNG HD321KJ 320.07 Sata
Thanks
Ninja
EDIT: i have also tried enable VGA mode, that does Ditto as well
Spec:
Xp Home Sp3
Gigabyte - 965P-DS3
Core 2 Duo 2.4ghz
2 gig Geil 800mhz
BFG 8800GTX oc
Corsair 620w Hx
Thanks
Ninja
