- 27 Nov 2012
Hi Guys,
I'm having an issue with 4k resolution displaying properly on my TV form xbox and pc via av receiver,
Using my Xbox One X and PC through my Yamaha RX V331 Receiver it just won't display correctly, 1080p resolution on both works fine, but when you switch to 60fps 4k Resolution it just has black flickering horizontal lines on both, and screen flashes & cutting out.
I have tried changing the cables with new ones, from the xbox and pc to the receiver, and the receiver to the TV but it doesn't make any difference, I have tried shorter cables, now using 5m cables to the receiver which should be fine for 4k HDR Resolution?
Do you think the receiver is faulty, or there is some interference at 4k resolution? as I said 1080p works fine
