Hey all,
I unfortunately come to you fine folks with another problem with my pre-built 'King Cobra' from OCUK
It seems I may have a fault water block/pump with the CPU cooler. Booted it up today to find it powered down on me 3-4 minutes into use. On checking the BIOS (hardware monitor) I noticed the CPU core temp was running flaming hot 95C.
I opened up the case and checked the CPU fan was running ok (which is was), and then checked the connector for the water cooler block/pump under the mobo to see if it had gotten disconnected (which it hadn't).
I purchased this system early-mid Nov 2011, so the CPU cooler is almost new. The cooler I use is: OcUK H2Flo Extreme Liquid Dual Fan CPU cooler (on an Intel i7 960 3.2).
I'm pretty sure the problem resides with the cooler block/pump as I have ruled out most other things (PSU, PSU connectors, PSU extension connector for CPU cooler).
Does this sound about right (faulty CPU cooler) ...or does anyone have any other ideas or suggestion that I could try?
Thanks in advance,
Chris
Thanks in advance,
Chris
