Faulty Dominator Plat?
5 Sep 2011
Surrey
Was just testing stability at a higher multiplier, ram has been spot on for over a week now at 1.62V CL8.
BSOD on reboot, then 01 ASUS Q code. On turning off and on again it won't see the DIMM.
It's under warranty obviously, but a bit perplexed. Flashed BIOS, still won't read the stick - but SPD reader gives this:
Is it definitely dodo?
I can't mem test it because it won't post :P DRAM error light and dreaded Q code 53.
Pretty sure it's dead :(
I do remember having a few problems getting it to read not long after buying but it corrected itself. Probably a runt DIMM.
Gutting though as it was a great kit, will get RMA going (Bought from OCUK). Bought the 2600Teamgroup stuff last night as well lol.
These 1.5V versions are based on Samsung 2Gbit D-rev (same as the rocking horse **** 2400C9 kit etc)
I've heard these munch prefer lower V, but I doubt I'd of killed it that way. I've run 1.8v through them
