- 22 Dec 2009
- bugle, cornwall (yay)
core 2 quad q6600 oc'd to 3.6
xfx nforce 680i sli
ocz reaper htc pc2-6400 800mhz
Ati radeon HD 5870
ocz gamexstream 1010w
Windows 7 64x 7600
tuniq tower 120 extreme
ok, i've had this ocz gamexstream 1010w power supply for a good 2 years now, and so far (i think) it hasnt been causing any problems at all. basically my problem is my computer seems to be making a few little high pitched whistles, specially if cpu gets under load, or until i started overclocking my computer and any fsb voltage over the stock 1.2v starts up the very annoying sounds.
i have my cpu oc'ed to 3.6 with the fsb at 1800mhz, so you can imagine what the sounds are like
they're there all the way from the post screen etc.. and im definitely not going to go back to 2.4 just so there's no sounds.. in hawx the frame rate is great, it just lags, like slows down and speeds back up in half a second, EXACTLY to the pattern of the wierd whistly sounds.
I have stopped every fan i have in this thing (apart from the psu one) and the sounds still carry on. my system is stable and everything, never had issues with stalling etc. And now the fan on the side of the case (came with it, cheap, has red, blue, green, and orange led's) has stopped spinning, although ONLY the green light is on. i turned my computer off, checked the connection and it still is doing the same thing.
so is the problem lying with the psu? and when i add power from overclocking is that somehow causing some malfunction? you just have to hear the sounds to believe.. unless its the mobo, but how can electricity flows make high pitched whining noises? im more worried about my system at the moment then the noises, but i would really like those gone aswell.
xfx nforce 680i sli
Ati radeon HD 5870
Windows 7 64x 7600
they're there all the way from the post screen etc.. and im definitely not going to go back to 2.4 just so there's no sounds.. in hawx the frame rate is great, it just lags, like slows down and speeds back up in half a second, EXACTLY to the pattern of the wierd whistly sounds.I have stopped every fan i have in this thing (apart from the psu one) and the sounds still carry on. my system is stable and everything, never had issues with stalling etc. And now the fan on the side of the case (came with it, cheap, has red, blue, green, and orange led's) has stopped spinning, although ONLY the green light is on. i turned my computer off, checked the connection and it still is doing the same thing.
