Faulty fans?
26 Aug 2004
South Wales
I have some case fans that are making a particular noise, sounds a bit like crickets.. so when quite a few are turned on it sounds worse like a light ticking noise.
Anyone know if the fans are faulty or can they be fixed? Been like this since i got them new and they weren't cheap. If i need new ones can anyone recommend some very quiet ones ranging from about 600-1000rpm that won't have any irritating noises and are not expensive?
Talking about case fans, 120mm or 140mm but if 140mm ones are still not as good noise wise as 120mms i would rather have those.
