Hi all, Im at my witts end here, yesterday I got a Driver stopped responding message & has recovered, then my Pc freezes. It happened a few times within 5 minutes & now when I boot up my PC the mobo splash screen looks ok & the display looks ok where it says loading windows for about 10 seconds but then the display shows lots of white lines on it & when I get to the login screen the display is 640 x 480 (something like that). If i boot in safe mode it's the same. My GPU is a geforce GTX770.
The card is only 6 months old, it isn't clogged with dust & all the fans are running so it isn't a overheating problem.
Ok this is what Ive tried :
1. Downloaded & ran display driver unistaller.
2. Restart pc & download nvidia drivers from there website & chose clean install (& restarted again)
It's still the same. Also I have 2 monitors connected & only 1 monitor will display anything.
If I put my old HD5770 back in after a driver update the displays are fine.
I'm somewhat confused, if the GPU is faulty then surely on the windows loading screen that would be all messed up but it's clear, but on the other hand even a driver clean install wont solve the issue.
The only other thing I can try is to reformat windows & then try it, which seems like overkill but I'm running out of ideas.
Any help appreciated.
