Hi everyone.
Ive got this card today https://www.overclockers.co.uk/showproduct.php?prodid=GX-282-MS&groupid=701&catid=1914&subcat=2379
Boots up into windows, but if I restart the PC using windows, I get nothing on the screen for 30-40 seconds then the desktop appears. This is only when the latest nvidia drivers are installed though. Everything is fine without them. (might try some older drivers?)
Also if i restart the PC using the button on the case I dont get this issue. Post shows up etc etc. Same from a cold boot also.
Been messing with this all day with Win 7. Just installed Win 10 and I get the same thing.
I have the Z87 HD3 Gigabyte MB with the latest bios installed. Also tried using the other PCI-E port and I get the same thing. Cleared the bios and checked all cables aswell.
Ive disabled the intel graphics in the BIOS aswell.
Surely I shouldnt have to wait 30-40 seconds for an image to appear.
Anything else I can try? Or does it sound like a faulty card?
Cheers.
Cheers.
