Faulty hdmi port can I use display port adaptor
23 Jan 2005
Hi can’t get a signal from my hdmi port and it’s very loose so was wondering if I could use a display port to hdmi adapter with the card, sure it’s a Radeon 580 series so has two display ports?
Thanks
Thanks just need something to check I haven’t damaged the gpu the hdmi connector bent, so just ordered one from the rainforest to test before I have to look at gpu’s
I been trying to find one that supports VRR as want to use dp. Some reports some have it working but none officially support it. Best Can get is 4k@120hz
It should definitely 'work' mate but you might find that the featureset is altered as compared to HDMI (eg restricted refresh rates/the passing of audio etc)
