- 27 Jul 2012
I recently got my rig up and running, but it's been without a I/O shield because I cant fit it in, my motherboard gets in almost all the way, but for less than half a cm the stand off screws wont match the motherboard. This isn't the stand offs fault, or the cases it's because of the I/O shield.
I want to know if its safe to leave it without an I/O shield, or can I leave it as I have done now (with the I/O shield sort of popping in from the outside, rather the inside)
Like I said I've tried a lot of things, but because of less than half a cm the stand offs wont fit and its because of some parts of the shield, when I had received the shield I sort of took out a lot of those metal tabs (I did it before as it made things a lot easier) but on this the mobo wouldnt accept it and half a cm wouldnt fit in.
