Faulty Laptop: Can they post with a faulty graphics card?
23 Mar 2005
Colchester, Essex
Hi all,
So my laptop doesn't start up anymore, I've taken the whole thing apart and tried to get it to boot with just the bare bones, but I still get the same symptom.
Press power putton
cpu fan spins
hard drive clicks a bit
no display at all
cpu fan stops
hard drive stops clicking
stays powered, but nothing displayed or happening any more.
It's a Toshiba A200-28P.
I've replaced the power supply block in case that was faulty, also reset the BIOS by removing the battery for a few days.
So that leaves me with either a faulty...
CPU
Motherboard
Graphics Card
(It has a separate graphics card btw).
So my question is if the graphics card was faulty wouldn't it still boot, although with nothing to see? Or could a faulty graphics card halt the whole booting process?
Any advice?
Chris
If you have a spare computer and spare usb stick download and make a linux puppy drive, see if you can boot form the usb, if so then it is most likely the HDD, however sounds more like the motherboard is at fault.
