What happens when a MAP sensor is faulty? The problem i'm having at the moment with my car is when I'm decellerating (ie foot fully off the accelerator) it will get to about 1200RPM where it will kangaroo before stabilising and movivng under it's own power at about 1000rpm. This makes motorway queue driving a nightmare. It may also do it if i've got my foot lightly on the accelerator maintaining a certain speed (1300rpm in 1st for example) it will drive steady and then kangaroos for no reason... It will do it when it's hot or cold. The TB looks quite new and it's a fly by type. The car drives as it should every other time, during *** and above 2k RPM etc..
I'm thinking it could be:
MAP
CTS
Lambda - but isn't this ignored when cold?
TPS
What are the symptoms of a faulty MAP as i could swap this easily with my friends clio.
Ps - it's a ph2 172.
Thanks.
MAP
CTS
TPS
Thanks.
