Faulty motherboard causing graphics issues?
15 Aug 2011
Hi,
I run a Tri-Sli 580GTX setup on a P8P67 WS Revolution motherboard. It's been working fine up until a few days ago when i attempted to start the PC. The machine powers up and even enters windows (i hear the noises, etc) but the monitor shows as no signal. I've swapped the graphics cards around, i've tried with just 1x graphics card (with all 3 of them) to no avail. I've tried an alternative monitor also to no avail. Sometimes, if i'm lucky, the machine does boot up correctly and works fine until the next shut down then the cycle repeats.
As the PC boots i find it hard to believe it's the RAM/CPU etc so do you think it's likely to be the motherboard? Any help would be muchly appreciated.
