Faulty PSU maybe?
28 Jun 2009
Łódź, Poland
Morning,
Just need some clarification that my instincts are indeed correct and the following problems are related to a faulty PSU.
-PSU clicks on rare occasions.
-Physical Memory Dump Error, experienced this when enabling and disabling crossfire and at other random events.
-The Corsair H50 120mm fan that cools the radiator is rather slow that i can make out the fan blades, and the top fan on the Antec 1200 case is the same.
PSU problem?
Not 100% sure but you might be able to take your computer to a local computer shop where they can plug your PSU into a machine to check the voltages for you. Should be free with the usual catch that you buy the replacement part you need from them. Worth checking out imo.
Had a PSU fault myself and my GPU fan would spin very slowly then stop. So it does sound PSU related mate.
