Ok I just got a enermax platimax 1500w off a mate. It was working fine in his old system. I want to power a asus z9pe-d8 and thought this psu would be great as it has dual 8 pin cpu power and for £60 I thought it was a good deal. However the system only boots once every 30 or so attempts. Taking a closer look one of the ATX 24 pin cables was pushed out of the connector and one tiny wire looks crimped, squashed too much. Could this be the issue?
A second odd thing is before I pushed the pin back in the psu made 3 or 4 fast clicking sounds when trying to turn it on.
So my question is, is the problem the 24p ATX lead or is it likely to be the psu?
The PSU seems to work powering an older board, and my asus z9pe-d8 works using dual psu's..... Thoughts? Help? pleaseee
 pleaseee
 pleaseee
 pleaseee
