Im currently finishing my WC loop and doing the air bubble bit. Ive flicked it on and off about 3-4 times (getting fluid through the system) and the PSU wont turn on any more.
I thought I broke it, so dug out my HX620 which worked fine. The loop is now 99% air bled, so thought Id put the other PSU back on and it worked....for about 4 times (on and off....connecting LED's to make sure theyre working).
Ive just clicked and noticed there isnt any capacitor whine like there normally is, so Im thinking the pump/ LED's are draining it and its taking longer than normal to recharge to start?
