- 26 Aug 2004
I bought this RAM around March 2007, so I've only used it for a few months. http://www.overclockers.co.uk/showproduct.php?prodid=MY-058-GL
Recently I've been getting errors in Memtest. Here are my results with running memtest for a few minutes.
4-4-4-12 2.0V and 2.1V: found around 59 errors
5-5-5-15 2.1v: found around 25 errors so far.
Seems like my RAM is faulty as I didn't get errors before.
The one thing I can think of that could have damaged it is trying to overclock it to 1000MHz at 2.3V but it is rated for 1.9V to 2.3V so I should still be able to RMA the ram.
Any advice as to what else I can try? Feeling a bit frustrated at the moment.
Will OCUK handle the RMA process? I'm not sure how to go about doing so.
Many thanks for any help.
Kind Regards
Kind Regards
